GE (PSS26MSRSS) Side by Side Refrigerator Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Odor in GE side by side Fridge
Despite thorough cleaning and trying several on-line suggestions - cannot get rid of fishy smell in freezer and fridge.
Cannot locate source of smell - even after removing back panel to fridge.
Tried baking soda - coffee grounds - newspaper - and finally mixture of baking soda and vanilla extract with no success.
Help.
Anonymous
Level 3:
  • Master 833 Answers
  • Posted on Nov 27, 2008
Anonymous
Master
Level 3:
Answers
833
Questions
0
Helped
519132
Points
1606
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
2answers
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
3helpful
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
1helpful
2answers
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
3helpful
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
67helpful
8answers
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Odours from fridge
frigidare makes a product called fridge- aid you can get it at lowes or any appliances parts store its made of activated coconut charcole it might solve you promblem
3helpful
3answers
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Top Refrigerators Experts
vince
Johnny 1000
