Lexmark Interpret S405 Wireless All-in-One InkJet Printer Logo
Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to recieve a fax ?
Attached to modem
  • Official Brand Answer 3,344 Answers
  • Posted on May 31, 2012
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923821
Points
5508
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
I WORKING ON A LEXMARK X642E WHICH CAN NOT SEND OR RECIEVE FAXES. WHEN TRY TO GO INTO FAX SETUP MENU IT SAY MODEM FIALED TO INITIALIZE!!
It possible that this is a bad modem, try turning off printer and unplug fax. If you are getting same error message, you need to get a replacement of the modem card.
For further assistance please contact Lexmark Technical Support.
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Not receiving faxes
for that U have to install software which comes with modem. der r few modems with this soft/w. it halts internet connection & recieves fax. and lateron resumes internet connection
I have a Lexmark all in one printer, X5270, I cannot send or recieve fax's, so would you tell me what I need to do to fix this, as it is suppsed to do fax's. I have Qwest dsl hooked up and have an...
I have an "all in one" model X2580. I haven't attempted faxing, but I just looked up faxing in my user's manual and it appears we need a modem with fax capability to do this. Before reading the manual, I assumed it was done over the Internet.
Text from manual:
"Make Sure:
The printer is connected to a computer that is equipped with a fax modem.
The computer is connected to a working phone line.
Both the printer and the computer are turned on."
Having Quest DSL should not be a problem. but it won't help you.
If you don't have a fax capable modem in or attached to your computer, is one included in your answering machine that could be attached to your computer? If so, this could help. If not, you probably need to install either an internal or external 56K modem with fax. They are not expensive and if you're lucky, someone might give you one id they're changing their ISP from Dialup to DSL or Cable Modem.
I will ask a Lexmark person I have been in contact with recently, but I don't think this can be done over the Internet.
Hp oficejet 5610 all in one not recieving
bad modem board. plug a phone into the ext jack see if you get a dial tone. The modem board can be bad even if it can send but not recieve.
Just bought and install fax machine (MFC640cw) I can send faxes but cannot recieve any. Phone rings, it recieves but it does not print.
It was installed on a VOIP connection. The Modem speed was changed to BASIC (9600 bps) which turns the error correction mode (ECM) off. Standard speed -14400 bps which may creat errors.
Steps: Menu/set - Fax - Miscellaneous - Compatibility - BASIC - Menu/set - Stop/Exit
Cannot send or recieve faxes
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
Post back with your results.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
