A light came on my french door whirlpool fridge saying cooling system off, what does that mean? who do i call or is this just an adjustment i need to make on the fridge. I cannot find any of my paperwork for the refridgerator.
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
SOURCE: Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
SOURCE: whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
SOURCE: Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
SOURCE: Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
