20 Most Recent Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator Questions & Answers
2answers
There is a bad smell that I get a wiff of when I
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
9/20/2017 11:57:12 PM • Whirlpool... • Answered on Sep 20, 2017
The freezer on my French door fridge is forming frostl. Why is this happening.
Is it frost on the freezer inside back wall or inside freezer towards the freezer door on the top of inside freezer box. If back wall then you have a defrosting problem. If it is towards freezer door then you have door seal problem and moist room air is getting inside your freezer.
12/6/2014 6:41:04 PM • Whirlpool... • Answered on Dec 06, 2014
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Hi, Sorry your having trouble so soon! First thing you need to check is inside the freezer section. The freezer fan, the fan is W10128551 and should be running along with the main compressor. Since the freezer is working, I would check the food on the top drawer or on the freezer door shelf. They too might be soft..without the fan. I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time.. John Wright
7/28/2014 12:08:43 AM • Whirlpool... • Answered on Jul 28, 2014
0answers
Maytag French door refrigerator not cooling refrigerator.
There is a defrost coil and timer to control it, you will have to check those to see if they work, If you are unplugging it to defrost it would take hours to clear the ice.
1/20/2014 10:26:23 PM • Whirlpool... • Answered on Jan 20, 2014
My freezer has bad ice build up on bottom and were
You have a drain pluged up in the freezer. You need to remove the bottom door and rollers take the back panel off and clear the drain.Use hot water after you get most of the ice out and take the back off the fridge and look for water to come in the pan.
9/19/2011 12:16:58 AM • Whirlpool... • Answered on Sep 19, 2011
Refrigerator is not cool. Thermometer in there
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/25/2011 11:45:19 PM • Whirlpool... • Answered on Aug 25, 2011
My whirlpool refrigerator is not cooling but my
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
8/11/2011 2:33:16 AM • Whirlpool... • Answered on Aug 11, 2011
I am getting a loud buzzing noise when it kicks in
Hi, the problem you are having could be down to a couple of things, now the first and most likely cause is that its not sitting dead level and this causes it to vibrate more so try moving it slightly, now the usual cause is down to it touching a cupboard or other appliance this to is solved my moving it slightly, so have a got at moving it about a small bit and you should find the noise will stop.
let me know if it dont ok
3/14/2011 11:30:10 PM • Whirlpool... • Answered on Mar 14, 2011
Freezer keeps overfrosting
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
8/28/2010 10:49:18 PM • Whirlpool... • Answered on Aug 28, 2010
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator. Here's how you can check for and change the water filter for your ice maker: 1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator. 2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape. 3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced. 4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place. 5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles. 6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter. If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM • Whirlpool... • Answered on Apr 03, 2024
How to replace freezer light
Delete To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
  1. Unplug the refrigerator to ensure safety.
  2. Remove all the items from the freezer to give yourself more room to work.
  3. Locate the light cover inside the freezer. The LED light should be underneath this cover.
  4. Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
  5. Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
  6. Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
  7. Remove the old LED light module from the freezer.
  8. Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
  9. Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
  10. Replace the light cover by snapping it back into place.
  11. Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM • Whirlpool... • Answered on Mar 29, 2024
Why is my whirlpool refrigerator ice maker not working on whirlpool model # WRF535SMBM00. It seems we have no water filter
https://www.appliancepartspros.com/repair-help/whirlpool-refrigerator-wrf535smbm00-repair/wrf535smbm00-ice-maker-not-making-ice.html Whirlpool Refrigerator WRF535SMBM00 Ice maker not making ice Causes of a bad icemaker cycling thermostat can include electrical malfunctions, temperature sensor issues, or wear and tear. Symptoms of a bad icemaker cycling thermostat may include: Inconsistent ice production. The icemaker not cycling properly.
HOW-TO: Whirlpool Refrigerator WRF535SMBM00 Ice maker ...
There is no water filter.
Where is the filter for water for ice maker located on
JustAnswer https://www.justanswer.com > Appliance Repair Jul 23, 2018 - This particular model does not have a filter built into it so that is why you can't find one. If you wanted to add a filter, you can get an in- ...
2/23/2024 6:13:04 AM • Whirlpool... • Answered on Feb 23, 2024
2answers
Whirlpool refrigerator running continuously won't shut off but is not freezing stuff in fridge and freezer is working fine
Sounds like the evaporator fan is not running. Pull the inside of the freezer back off to expose the motor and replace it.
2/21/2024 6:59:51 PM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool freezer defrosting too often causing food to thaw.
If it has a defrost timer, some are adjustable. If not just replace it. https://www.google.com/search?q=Whirlpool+freezer+defrosting+too+often ..
1/7/2024 7:49:35 PM • Whirlpool... • Answered on Jan 07, 2024
Whirlpool ET1MTKXKQ20. Temperature control.
Question edited for clarity, spelling of maker, toss in a load of CAPS. Question moved from Cars and Trucks. Yes they do. https://www.google.com/search?q=whirlpool+et1mtkxkq20 ..
1/1/2024 3:13:20 AM • Whirlpool... • Answered on Jan 01, 2024
Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator Logo
22 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
whirlpool refrigerator not cooling but
  • Refrigerators
