Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
CompactFlash I & II
Sony Memory Stick, Memory Stick PRO
Secure Digital (SD) Card
MultiMediaCard (MMC)
xD Card
Sony Memory Stick Duo (with adapter)
Mini Secure Digital (Mini SD) Card (with adapter)
Sony Memory Stick PRO Duo (with adapter)
SanDisk TransFlash Memory Module (with adapter)
RS-MMC (with adapter)
Guidelines to print via bluetooth:
You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
Note: Bluetooth adapter sold separately.
Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
The Lexmark P350 uses #43 and #45 color cartridges. Here's the link to download the Lexmark P350 User's Guide: http://www.lexmark.com/publications/pdfs/2007/350/v759461_en.pdf. For the power cord, check at any electronic shops around your area for a 2-prong power cord. For your convenience, I suggest you contact Lexmark Technical Support to request for that. They can send you one for free. Just give them your contact info and the serial number of the printer for documentation purposes. Hope this helps.
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
