Question about Lexmark P350 InkJet Photo Printer
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Posted by rossallwrigh on
Lexmark
  • Official Brand Answer
  • 3,344 Answers
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
p350 lexmark saying that a - printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Posted on Aug 15, 2011
In my nokia 6300 phone , phone memory is running when i receiving data via blue tooth. how to change it to memory card?
Hello 000Krishna,
While receiving the data via blue tooth data will store in phone memory always.
If you want to transfer in memory card.
Then connect the phone in computer using the PC suite.
Please download the Nokia PC suite from
http://www.nokia.co.in/support/download-software/nokia-pc-suites
Then transfer your data from phone memory to memory card.
2helpful
Im trying to turn on blutooth on my nokia 5800 it is coming unable to perform bluetooth operation
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 • Cell Phones
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
2helpful
Blue Tooth recieving error ''operation failed'' in Nokia 6233
go to bluetooth settings and put save in memory card
1helpful
Is there any way to save the messages from the inbox (on lg scoop) to the memory card
I don't believe you have the option to send the text massages to the memory card, most phones can only send them to blue tooth or send them email. You should have options when you open the message, it will say something like forward, send, blue tooth.
I looked at the manual for the ax260, scoop, there are different models.
This says you can only forward, this means you could send them to a email address, but you can't save them to your memory card.
If you need further assistance just ask(post it).
Feb 05, 2010 • Cell Phones
1helpful
Cant down load
hello there...that's right you can get a usb data cable, blue tooth ,or memory card reader to transfer you pictures to your computer....
you can directly print the picture as some of the printers come with card readers built in which is very convinient
consider visiting a mobile accessory shop you will have all the options there
my best pick will be memory card reader if you already have a printer...it is very cheap...and can read multiple cards...so in future if you change your mobile you will not have any problem
like with usb cable (different for different phone)
blue tooth and getting a new printer is a costly affair...blue tooth often have connectivity and software issues
go for memory card reader ...cheap ,reliable ,fast and best of all
Hope this helps
Cheers
I need help transfering files from memory card to my phone which is a MOTOROKR Z6M
Lets say you want to transfer a picture from your media card to your phone. Open the media gallery-----select pictures-------when 4 pictures load up....CLICK OPTIONS...THEN CATEGORIES. (IF IT IS ON MEMORY CARD GO TO CATEGORIES AND SELECT WITHIN A CATEGORY FOLDER, IF IT IS ON THE PHONE IT WILL BE IN "NO CATEGORY")FIND YOUR PICTURE......HIGHLIGHT IT THEN..... click "options" then "manage". Now........select "move" or "copy" MOVE/COPY FILES TO: WINDOW WILL OPEN. IF IT IS A PHONE FILE IT WILL SAY "MEMORY CAR OR BLUE TOOTH. IF IT IS A MEMORY CARD FILE IT WILL SAY PHONE OR BLUE TOOTH. MAKE YOUR SELECTION AND CLICK THE CENTER NAVIGATION KEY BUTTON TO SELECT. IT WILL SAY FILE WAS MOVED OR COPIED SUCCESSFULLY. DONE DEAL.
Jan 12, 2009 • Cell Phones
How to get photos off phone?
Hope this help
Cheers
2helpful
2answers
Sending photos via bluetooth
if photo are very important then you simply copy those photos in
phone memory,and then you able to send those photose via blue-tooth,if not purchase a card reader to read the memory card
if you have data cable then nothing to say connect it to usb port run the pc-suit.
Blue tooth connectivity
I would suggest u to remove ur memory card and receive a similar file on the phone memory…try to play it…if this happens then the problem Is there with the memory card…it may b a virus problem…format ur memory card…take backup of ur important data in the memory card and format it...
Lexmark P350 InkJet Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Ekse
Michael Thomas
Michael Thomas
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
