Tried holing channel up & stop up/dwn & open power & open just keeps flashing between time & please wait
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Details about this fault has been described here.
SOURCE: DVD locked in and door is not opened
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
SOURCE: DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
