Was watching a dvd on it and suddenly the ps3 turn its self off and now wont turn on anymore?
SOURCE: ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen
remains blank for more than 30 seconds, you may need to perform the
following steps to reset the Video Output Settings.
SOURCE: dvd stuck iin hard drive
you need to call the sony tech support, the motor that controls disk eject and recieving may have failed. cant say for certain but you do need to call sony.
SOURCE: playing my ps3 and suddenly it turned off and wont turn back on.
Hi. this is a basic power supply issue. it has failed. you will need to replace the internal power board(supply). this will fix your issues.
SOURCE: ps3 wont eject disc just turns it self off
have the sony turned off then before turning it on place your finger over the eject button then turn the console on with your finger still in place this is the eject override method it should spit out your disc if not u may have other hardware issues
SOURCE: my ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
