Worked fine with Analogue TV but does not seem to trasmit Digital TV
SOURCE: Connecting up Digital TV, DVD recorder and VCR
If I may offer an unconventional solution in addition to the initial post...
Connect all TV, VCR and DVD Recorder as to any way you want to connect them or as otacon have posted.
However, from your cable input from your provider, use a 3-way splitter. Connect the 3 outputs to the individual ANT INput of each of the 3 units (assuming all 3 have Cable/ANT INputs).
With this method all 3 can receive TV signals, both the VCR and DVD-R can record (even simultaneously) and you can switch watching one program on the TV, while recording another program in either the VCR or DVD-R or both.
SOURCE: Grundig colour tv lost digital channels
there is prob in tv cicuit . memory ic may be curupt . if u r not a tv technician then connect a tv engineer
SOURCE: Sony KDL-40V4000 lcd tv, can't get rid of the on screen clock.
Press " i " on TV remote and on-screen display will disappear.
SOURCE: Analogue or digital TV?
This is a Analog TV..
User Manual available at http://www.p4c.philips.com/files/2/25pt4458_05/25pt4458_05_pss_eng.pdf
Hope this Helps..
SOURCE: Sony digital tv KD 32DX40U wont pick up digital signal
The tv is a 2k model - I have the same one, digital is now 8k so it won't work digitally anymore.
2K Equipment
