Question about Toshiba Televison & Video
Cant seem to tune in after digital switch over not got any chanels
Posted by magsjohnston on
Scott Bailey
    President:
  • 720 Answers
If your tv has both analogue & digital tuners, you can usually HOLD the channel button for 2secs to switch between analogue/digital tuners.
If you set does not have a digital tuner, then you will need to use an external tuner box to receive digital tv - the external box would be best connected to your tv via 'Component + Audio' or 'HDMI' cable.
Posted on Jun 22, 2011
Anonymous
    New Friend:
  • 84 Answers
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
When i switch off tv and turnit back i loose some of the chanels
You may or may not have a real problem with the set, using a antenna of some sort for this or what?
Dec 21, 2012 | Televison & Video
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
I HAVE A FEW CHANELS THAT GOT BLOCKED WHILE TURNING THE TV, NOW THEY SKIP THOESE CHANELS. HOW DO I UNBLOCK THEM?
Go to your tv menu, and find the auto tune section.Try running it again. otherwise you can unblock just the channels you want. It might have blocked channels that didn't seem to carry a signal.
Feb 28, 2011 | Televison & Video
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
Since digital switch i cant auto tune my telly with out a password
since digital switch i cant auto tune my telly with out a password
Dec 04, 2009 | Toshiba Regza 37HL17 37 in. LCD TV
Just got a n64 off ebay power cable and an antenna cable came with it. no idea how to tune the tv so i can play it!!!!!! i have tried manually and automatically searching through all the components and...
It has been a long time since I have used one but I believe you can hook it directly to the rca jacks in the back of the tv... then I believe you need to be tuned into the AUX chanel on your tv set ... some tv's if you hit 00 this puts you to it ..others start from chanel two and go down ... hope it helps .. have fun playing the 64
Oct 16, 2009 | Nintendo 64 Console
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
Cant tune in channels on freeveiw (built in to system )
u need to have your aerial cable directled plugged into your freeview box
May 31, 2009 | Philips Televison & Video
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
