CD/DVD Drive Tray problems There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD/DVD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc. If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Are all the Windows and Gateway updates and Hotfixes in? Look for a DVD rom fix on the Gateway website support. If there is no disk in the drive and it opens, you may want to replace it. You can try a work-around, I have no idea if it will solve the problem, but at boot open the BIOS, go to Boot sequence, Change HDD to boot first. DVD/CDrom 2nd or 3rd.
It won't play for one of two reasons: 1. There is something inside the DVD player, which keeps it from playing. 2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Visit this site for more details.Type in the site name Electro-help either to Google or Yahoo search box and click search.It is an electronic equipments service help site.All details you want are there.Note the position of hyphen in between words in site name, when you type it in.The site will appear as it is in web.
Never force it, just use the remote. If it won't stay in, unplug the unit and wait a while. I think we get viruses from the TV signal which might be temporary (hopefully).
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc. Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens. If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage). If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
