Mitsubishi WS-73713 73" Rear Projection Television Logo
Posted on Nov 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi TV green light stays on but won't power up.
Have gone through replacing both ICs and some fuses here and there. got the tv to work for a while and then it went out again. just re-replaced the ICs.
i plugged the tv in and the green light came on and stayed on. tried powering up and it did nothing, but the green light remains on.
any help?
  • hammc Nov 14, 2008
    Also: it is a WT-2311
  • Anonymous Dec 22, 2008
    my tv sometimes turn on and sometimes not and the green light keeps flashing please help!
Larry
Level 3:
  • Mitsubishi Master 5,042 Answers
  • Posted on Nov 30, 2017
Larry
Mitsubishi Master
Level 3:
Answers
5042
Questions
Helped
1241951
Points
18413
Your power board has issues, you can order one from shopjimmy or ebay
5 Related Answers
Anonymous
  • 279 Answers
  • Posted on Sep 07, 2007
SOURCE: mitsubishi WS 65809
This question predates my joining Fixya, so I'm just getting to it. Are you still having this problem - and have you tried anything else? If you can update me on the current status of this, I can try to find some information to help you.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jun 15, 2008
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Anonymous
  • Posted on Sep 19, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Anonymous
  • Posted on Nov 18, 2008
SOURCE: Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Apr 03, 2009
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
1helpful
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
Mitsubishi 65711 TV will not power on
Did you check the power supply and does the supply have bulging capcitors? if so change those. check fuses as well those are located on the main board as well.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
TV won't stay on
Replace both of your STK ICs will have part number on them.
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
Press remote to power tv green light comes on than shuts off
Replace Both of your convergence ICs they are big black ICs with STK on them use number on ICs if they are 110s use 180s if 020s use 040s other wise use same number on ics. Parts call 1-800-223-3205 or go to www.electronix.com .YES TV is worth fixing if all 3 tubes are Good.
2answers
TV power will not stay on.
Not worth to fix.Either power supply,sensor or convertion board are too costly for the part.Buy a new TV.
solutiondoct
3answers
Power problem
Most likely the convergence ICs are bad. These aare large black ICs attached to a heatsink. They will be marked STK393-110 and have about 15 pins or so. Replace these and check the fuses marked F9A01- F9A06 on the same board. Replace any open fuses after the IC replacement and report your results here.
Dan
2helpful
4answers
Please help me fix my tv
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
9helpful
5answers
Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
