Mitsubishi WS-73713 73 in. Rear Projection Television
Problems with Mitsubishi WS-73713 73 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WS-73713 73 in. Rear...
Troubleshooting and Support
Solved Problems for Mitsubishi WS-73713 73 in. Rear Projection Television RSS Feed
View More Results for Mitsubishi WS-73713 73 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WS-73713 73 in. Rear Projection Television RSS Feed
Answer
When I turn on my ws-73713 with a feed in the component input it will display and scroll wavy lines... (More)
Answer
I can only seem to get 480 on my set, additionally, bottom of screen seems to be cut off (such as... (More)
Answer
Have gone through replacing both ICs and some fuses here and there. got the tv to work for a while... (More)
Answer
hello, hope someone can help me fixed this Mitsu WS-73713 projection TV. the problem is after... (More)
Answer
I have a problem with one mitsubishi WS-73713.. First problem is continous blinking green. I fixed... (More)
Answer
can see picture but it has a wave at the top and the yellow blue and green are not synchronized
Answer
I just got a 73" Mitsubishi DLP. The sound is like it is all mono..I have adjusted all the... (More)
Find a Manual
Mitsubishi WS-73713 73 in. Rear Projection Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WS-73713 73 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WS-73713 73 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WS-73713 73 in. Rear Projection Television
Key Features
Screen Size
73 inch
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Remote Control
Remote Control
Multibrand
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Stereo
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
29.88 in.
Height
65.75 in.
Width
65.25 in.
Weight
410 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
