Mitsubishi WT-42311 42 in. Rear Projection Television
Problems with Mitsubishi WT-42311 42 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WT-42311 42 in. Rear...
Troubleshooting and Support
Solved Problems for Mitsubishi WT-42311 42 in. Rear Projection Television RSS Feed
View More Results for Mitsubishi WT-42311 42 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WT-42311 42 in. Rear Projection Television RSS Feed
Answer
What can be done for the error codes 2 then 4 on a mitsubishi WT-42311
Answer
SD Tech or anyone who can help, My Mitsubishi WT-4609 keeps turning off by itself and when I try to... (More)
Answer
when you turn my tv on it turns right back off what should i do?
Answer
what does a 2-2 code mean on the wt-42311? how do i solve it?
Answer
Water spilled on top of Mitsubishi WT-42313 and now screen has discoloration. How do I clean and/or... (More)
Answer
There is blue outlines of images on screen. colors are off.
Find a Manual
Mitsubishi WT-42311 42 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WT-42311 42 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WT-42311 42 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WT-42311 42 in. Rear Projection Television
Key Features
Screen Size
42 inch
Display Capabilities
Aspect Ratio
16:9
Remote Control
Remote Control
Multibrand
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
25.13 in.
Height
34.25 in.
Width
38.25 in.
Weight
110 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
