Our fax machine will not send faxes at all, it trys three times then beeps, then prints out a page that says " poor line condition/ low memory"
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
SOURCE: OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If
you get a MEMORY FULL message while scanning the first page of a fax,
press Stop to cancel the scan. If you get a MEMORY FULL message while
scanning in a subsequent page, you’ll have the option to press Start to
transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending
on your typical faxes, MEMORY FULL errors can occur frequently. If this
happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This
will mean you don't add any more to the memory and may be able to send
faxes. There is a possibility that you will only be able to fax using
manual transmission, but at least you should be able to use the machine
to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
SOURCE: poor line condition-can't send fax
Try turning off the E.C.M. mode off ( error correction mode )
I have had a lot off problem's with communication problem's with this function turned on.
It is in your manual under advance fax function.
if need more help let us know.
SOURCE: Consistently receiving poor line condition error
The other fax machines are not on the same line though, right? Try installing a line filter.
SOURCE: what does poor line condition mean? i can receive
If this happening only on one fax number, its the other side, could be their line or fax machine.
Just make sure for youre end that the telephone wire is in the LINE jack of fax machine (NOT EXT) and other end should should go directly to wall jack (meaning no extention or splitter)
