Samsung SF-5100 Plain Paper Laser Fax Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to stop to print the journal after send fax everytime?
Anonymous
Level 3:
  • Master 488 Answers
  • Posted on Nov 27, 2010
Anonymous
Master
Level 3:
Answers
488
Questions
0
Helped
231284
Points
1359
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Selecting On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
How to set perimeters to get confirmation on faxes
at the fax parameter ( F7-04) you may look for COMM JOURNAL.
inside COMM JOURNAL, you may choose what will it print. is it always, during error sending, or never print.
that's it :)
1helpful
2answers
1helpful
Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
2answers
Verification stamp
there is no function to print it on the fax you sent but you can have a come journal.
press the following.
function-7-4-start-1-2-start-2"should say always" start stop then this will give you what you want
In the - IND. XMT JOURNAL - the destination number is wrong
to set the com journal, press function-7-4-set-1-2-set-2-set-stop
to check the phone number you could look in function-7-1-set- keep hitting set till you see the phone number
Panafax UF 885 resets itself when trying to print comm journal
sounds like your firmware might be shot and it needs to be reinstalled, if your in canada i can recomend a tech
2answers
Pana fax uf 8000
I'm not sure which key is used on that model but look for a key that says one of these: menu/user settings/reports/program.
what you are really trying to do is get to your reports programming section, then select tx report, then choose print tx report and will fix your problem, you may want to change you fax number if that number changed also.
mikey
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
