When watching keeps freezing wont do anything have to turn off at the mains. also does this when recording (only one thing and watching at same channel at same time) then comes up no signal only 3 months old and had new arial fit by a proffesional. freeview vin telly works when we switch the box off so know its not the arial. not got reciept so not sure if we can return it really frustrated when watchuing something and it crashes halfway through and miss the rest of the proggramme.
SOURCE: UK TV History Freeview Channel
UKTV History now finishes at 18:00, when it is replaced by a new 'cheap-tacky-repeats' channel called 'DAVE'. Worst thing Free-view has ever done in my mind.
SOURCE: TruTech PLV1615T 15 in. LCD TV
These TV's have a common glass see-thru fuse in the power supply.Remove the back of TV and you'll see it in the power supply section,the area where the power cord is soldered to the c.board.Remove fuse and test the fuse for continuity with a multimeter or continuity tester.You CAN"T ALWAYS tell if its blown just by looking at it.
I've repaired 2 of these already that I bought cheap on Ebay.Both had defective fuses.
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn
tv back on and you should be prompted to go through the plug and play
setup again - go through everything and then all should start working
OK (it did for me)
HTH
SOURCE: Vizio 37 inch lcd
I haven't had any problems with my VIZIO, but I have had several really good experiences with their service people, so I would recommend calling them up. They have great product guaranty and if for whatever reason you got a defective item I'm sure they'll help you out.
SOURCE: KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
