JVC KD-S640 CD Player Logo
Posted on Oct 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just stopped playing
Unit lights up no error messages, and no sound. Removed unit checked for possible loose wires. Any ideas????????
  • Lanec5 Oct 30, 2008
    WILL DO, THANK YOU VERY MUCH.
Francisco Mauricio G
Level 3:
Genius:
  • JVC Master 1,551 Answers
  • Posted on Oct 30, 2008
JVC Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525438
Points
4192
Change the audio amplifier IC maybe are damaged
2answers
Kenwood 6020dnx shows DC offset error ONLY AFTER I started the car.. before it was playing music fine. When I started the car it showed the message
That error is normally a shorted speaker wire but starting the car won't cause that. Possible problem could be the dimmer wire was used as a ground by mistake. Lights come on when the car starts. Another is too high of voltage. Car rests at 12 volts but is around 14 when running. Was there a plastic piece on the red or yellow wire that got cut off during the install? They have a resistor inside that keeps the voltage down.
5answers
Signal And Brake lights
The flasher unit is located under the dash, near the steering column. This could also be caused by a faulty ground wire. Check the wiring for broken, bare, or loose wires or connections.
Plays music for about 3 mins then stops
Possibly shorted unit. But sounds more like it reset all settings to 0. check ground on head unit itself.
It displays a message: dl and stops
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
1helpful
Won't start and the display alternates between dl and f
Hi. This is a Door lock mechanism failure code.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit. Make sue it is mounted correctly, and not loose.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
If the door lock unit is mounted correctly, and the wires that link the device to the main control module, and connected well, this will lead to a failed lock mechanism. replace the door lock mechanism, in this case.
2answers
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 • Dishwashers
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
Replace the door lock mech if the wiring is ok
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
