The machine stopped during a cycle, the pump keeps working, but if I turn on a program it says "C3" and peeps continuously. The lights for pre- and main- wash are also blinking. I cannot open the door. Can you please help me?
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
SOURCE: My washing machine AEG lavamat
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
SOURCE: My Washing machine Brand :
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
