MY AEG FAVORIT DISHWASHER, ALARM SOUNDED 5 MINUTES INTO CYCLE, TURNED OFF ON CONTROLS, PUMP CONTINUED & WILL ONLY TURN OFF IF MAINS OFF. I DISCONNECTED WASTE PIPE, & TESTED, NO BLOCKAGE & EMPTYING OK, BUT PUMP WILL NOT STOP? CAN I RESET IT? ANY IDEAS PLEASE
Or a faulty timer.
Try over filling with water to reset the level switch. May help.
Check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
SOURCE: AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
SOURCE: BEKO D3422FW Dishwaser stays on the pump out cycle.
I can confirm Solution #2.
This usually happens whe you have a blockage in the waste pipe. For some reason, once you've cleared the blockage, the dishwasher doesn't detect that water has now passed through the system, even if you send through more water via filling the base (I did this about 4 times totalling 24litres of water and it still didn't reset).
Tilt the dishwasher back (I only had to tilt it about 30 degrees), this resets whatever switch it is that turns the pump off and allows it to fill with water.
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
