Freezer will not freeze any thing nor will the ice maker make any ice. Both sides are to warm. 10 years old
Check the condenser at the bottom part from the front grill. could clogged with dirt. remove the dirt and check the compressor and condenser fan at the back side if they are running. it should be running.
if the compressor is very hot, un plug it for 4 hours and test it again. put the cover back at the back side if you would test it again.
tnx 4 using fixya,
drcool
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Freezer nor refrigerator getting very cold - about 40 degrees on both sides?
Compressor and fan both run. The rear cardboard panel was clogged with dust, and there was significant dust and dirt coating everything. Removed rear cover, cleaned all parts. Compressor and fan both run continuously. If I manually cycle the defrost timer at lower front of refrigerator, it does shut off compressor/fan, then continuing manual rotation of timer cycle reactivates compressor/fan. Where are freon charge valves to check freon pressure? I cant find them.
