Back to:
Tags:
Sony Xplod  Car Subwoofer
I broke the metal bit where the wire connects and...
posted by Thicky on May 31, 2006
i connected the wire to another metal part for now.. but my bass has dissapeared.
what type of metal is it?
i was thinking of using a souldering iron to "glue" the wire on but im afraid it may not work and ill jus f*ck it up even more.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 24, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
if u use a soulder the wire straight to it it should work fine but it would be a bitch to get it undone when u want to un hook it
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on i broke the metal bit where the wire connects and dont know what to do:
I don't want to Accept this solution
Solution #2
posted on May 20, 2007
Not Rated (0)
WOL2502
Rating: 0%, 0 votes
HI THERE IF YOU HAVE A CLEAN CONNECTION IT WILL WORK FINE MAKE SURE YOU CLEAN THE METAL UP FIRST SO ITS BEAR IT WILL EARTH PROPERLY I INSTALLED MINE YESTERDAY AND ALL IS FINE HOPE YOU GET SORTED THANKS WARREN
Thank You!
Solution #3
posted on Feb 20, 2007
Not Rated (0)
youngin
Rating: 100%, 1 votes
Yes, I would solder it back to its original place and it should work like normal
Thank You!
Solution #4
posted on May 31, 2006
Not Rated (0)
bmwrider
Rank:Wiz Wiz
Rating: 85%, 1767 votes
Sorry I'm not going to touch this one with a bargepole.
I will suggest you go to a car hifi installer and get him to have a look at what a mess you've made and see if it can be fixed.
Thank You!
Can you Help with these Car Speakers and Subwoofers problems?
car radio code for nissan pathfinder 2000
mitsubishi montero car radio unlock need help
When I try to play my ipod on the pioneer avic 900bt I get...
how to connect digital cap pc2.0f
my battery went dead in my car and my head unit wants a...
Loading problems.
Repair Service
Find Car Speaker and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
