20 Most Recent Sony XPlod CD Player w/MP3 Playback CDX-GT40W Questions & Answers
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Sony XPlod CD... | Answered on Aug 16, 2018
While the head unit is off press and hold in the volume or source (SRC) button it will bring up a menu with different options go to demo mode and turn it off hopes this helps thanks Jeff J&D services
Sony XPlod CD... | Answered on May 15, 2014
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
Sony XPlod CD... | Answered on Jun 14, 2011
You enter a code on the source device, enter the code again on the head unit (using the remote control is the easiest way to do so), and the two devices connect.
Sony XPlod CD... | Answered on Mar 29, 2011
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
Sony XPlod CD... | Answered on Mar 15, 2011
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Sony XPlod CD... | Answered on Mar 04, 2011
You can get the manual from Sony.
Sony XPlod CD... | Answered on Mar 02, 2011
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Sony XPlod CD... | Answered on Feb 17, 2011
do you mean the blue light on the power button? it sounds like your radio's switched power input (usually red) is hooked up to a 12 volt constant source.
Sony XPlod CD... | Answered on Feb 22, 2010
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Sony XPlod CD... | Answered on Jul 27, 2009
this seems to be a wiring problem. get a technician and have the wiring check.
Sony XPlod CD... | Answered on May 27, 2009
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Sony XPlod CD... | Answered on Apr 11, 2009
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Sony XPlod CD... | Answered on Feb 20, 2009
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Logo
Popular Tags
23 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
sony mp3 xplod car radio buttons wont
  • Car Audio & Video
