FixYa.com
Sony XM-2150GSX Car Audio Amplifier
All Products > Sony > Car Amplifiers
Problems with Sony XM-2150GSX Car Audio Amplifier?
Search inside Sony XM-2150GSX Car Audio Amplifier Knowledgebase
Troubleshooting and Support
Solved Problems for Sony XM-2150GSX Car Audio Amplifier RSS Feed Post a New Problem
Wiring Diagram for Sony car amplifier...
Hi, I bought a Sony car amplifier XM-554ZR 4 chanel. 2 for front speakers & 2 for back speakers. how i will...
4 Solutions
overcurrent comes on when i turn up the...
Everytime i turn up my volume and the bass is hitting hard. If it hits too hard then it will jus cut out. sum1 PLZ HELP...
1 Solution
amp overcurrent problem
i have an XM-2150GSX sony 760 watt amp, not the best, but my overcurrent light comes on every time i turn the amp on,...
1 Solution
need a lil ore help!!!
ok i have one more thing that i cant figure out i have got the diagram for the amp n i hooked everything up the way it...
1 Solution
I NEED HELP WIRING MY AMP
look guys this might sounds dumb but i got a amp n i grabed it from a buddy of mine but i dont kno how to hook it up n...
1 Solution
can you help??
1 Solution
Subwoofer Wont Work
I have a 2000 BMW 740i. I recently bought a sony xplod sub and amp. I went to a local audio store and had them wire and...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms150 W x 2
RMS Power at 2 Ohms190 W x 2
Performance
Bass Boost Frequency40 Hz
THD at Rated RMS Power.04 %
Signal to Noise Ratio100 dB
Frequency Response20 Hz - 20000 Hz
High - Pass Frequency50 Hz - 300 Hz
Low - Pass Frequency50 Hz - 300 Hz
Dimensions
Depth10.25 in.
Height2 in.
Width14.06 in.
Other Features
MOSFET ampYes
3 Way ReadyYes
Input Voltage14.4 volt
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
