20 Most Recent Sony Z2X-1200 SPL Car Amplifier (1200 Watts) Car Audio Amplifier Questions & Answers
if you have the model number handy i can tell you
but most sonys are marked like this ..
+12v goes directly to the + termanl on the battry
GND goes to a solid metal object on the car (ground)
REM remote turnon goes to the remote turn on from your headunit
unbridged speaker outputs
+L positve left speaker
-L negative left speaker
+R positive right speaker
-R negative right speaker
ok to bridge a amp (must be capabul of doing so) look for a mono switch and set to mono ..
then take the +L channel put it to your subs + and take the -R channel and put it to the - of your sub
also set the cross over switch to LPF if your running bridged for a sub
if that is a bit hard to understand msg back with the model number of the amp and i can get u the orignal manual for the wireing diagram
hope that helps
Sony Z2X-1200... | Answered on Dec 16, 2018
If your deck has RCA's use those. If not then run your high level input wires to the output wires on your deck. If it is not stock, then it should have RCA's
Sony Z2X-1200... | Answered on Sep 08, 2011
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Sony Z2X-1200... | Answered on Nov 03, 2010
No longer listed for sale as it is old. $40 used.
https://picclick.com/Sony-Marine-Stereo-Cd-Receiver-Deck-Cdx-M501P-183497958733.html
look at Jenson Marine instead. I have one on a Boston Whaler.
https://www.jensenmarinedirect.com/
Sony Car Audio &... | Answered on May 12, 2019
+ to battery, - to ground metal in the car location where you're installing and rem to blue on back of radio.
Sony Car Audio &... | Answered on Apr 16, 2019
I'm pretty sure it means that you have to much mucis downloaded
Sony Car Audio &... | Answered on Apr 04, 2019
If it ain't turn on at all check your fuse box. It could he a fuse under hood in car under dash. If the fuse is good then pull the radio out. Do a smell test on it. If you don't smell anything suspicous then check your red yellow and ground wire. Yellow being your switched 12v which turns off and on with ignition. Check red wire also. Also ground wire is very important.if none of those work it will need to be replaced. Check fuses carefully. A blown fuse can sometimes be easily missed
Sony Car Audio &... | Answered on Apr 02, 2019
Hi nick, there can be many causes for this fault.
1. your speakers or speaker cables are faulty, then this problem will come up.
2. your installation is done incorrectly, or with the wrong gauge of power cables can cause this problem.
3. your vehicle battery could be weak.
4. you could have an internal problem with the amp only, which needs repairs.
cheers.
Sony Car Audio &... | Answered on Mar 09, 2019
Hi, check all the switches on the face panel, if the switches donot have a "click" feel when pressed then they are faulty.The face panel then needs internal repairs. Also check the gold connections behind the face. Check to see if all the contact pins are clean and shiny, and the same goes for the contact pins on the head unit side as well. cheers.
Yes, speakers are rated by power handling capacity, Having an amp with less than the power handling o speaker will not hurt anything.
Sony Car Audio &... | Answered on Feb 16, 2019
Car Audio & Video Logo
Popular Tags
15 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
wiring diagram sony xplod amp
  • Car Audio & Video
