20 Most Recent
Sony XPLOD CDX-GT200 CD Player Questions & Answers
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Sony explod won't turn on
this unit has a detatchable face take it off by pressing the button on the bottom left corner and take a pen and push the RESET button located near the connector on the unit than put the face back on and press the SOURCE button this should fix it and turn it on note you will have to set the clock as well as all radio presets and sound settings
Yes, also.... I am trying
Make the audio only show the time no sound. Try pressing it off and then press a button not source. Then go through the settings by pressing the large round button there should be an option called aux a set that to on.
Sony xplod controls not working,
unit most likely has either malfunctioned or has dirty contacts take the face off and press the RESET button if this does not fix it take a QTip and some rubbing alcohal and clean the contacts on the face and unit this unit does come with a remote try using that
Looking for wiring diagram for 1998 Nissan Terrano
it is easier to go to your local car spares shop, and get the leads that are available for nissans and sony stereos. they plug in behind the dash, and straight into the stereo. no chopping wires and quite cheap to buy
Diagram abot wire harness
A wiring harness for the unit is most likely more than you would pay for a used unit at a pawn shop. Most sony receivers have the terminals labeled on the circuit board. If you are lucky, you can find a dead one at a stereo shop or repair shop near you. They didn't name them explode for nothing. Be careful.
Got power to cd but no display
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
