Question about GE WSXH208A Front Load Washer
Rubber gaskets came out
How do you get the rubber gasket back in? it is te one in the front load part that keeps the water from spilling on to the floor
    Problem Solver:
  • 16 Answers
Remove spring retainer ruber door boot remove the rubber.looking for the clamp loose it put the door boot back in the tub(drum)tie the clamp go revert the procedure(take out)good luck
Posted on Oct 13, 2008
I have mold all around the rubber gasket on the fromt of my LG washer. How can I eliminate this?
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
Service manual and more HERE
Feb 10, 2011 | LG WM-1832C Front Load Washer
Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
Water collects in the seal....
Just replacing the gasket.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 44102 Front Load Washer
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Oct 12, 2008 | Whirlpool Washing Machines
Rubber piece
If you mean in the bottom of the gasket between the drum and the door the hole is to allow water to drain from the gasket to prevent standing water which will smell .
Aug 08, 2008 | Malber P25 Front Load Washer
Repaired!
congratulations, it may help you if you use a bit of water with a bit of detergent as lubricant when snapping back the rubber gasket in place.
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
Rubber gasket Bello!
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Apr 29, 2008 | Bosch WFMC 3200 Front Load Washer
Frigidiare GLTF2940ESO front load washmachine
it has a fine ring clamp. find it and check it if its broke. they don't normally comes off easily. you will need a phillip screw driver to tighten it. unloosed it first, put the ring inside the gasket, then force the gasket gently to the metal round frame, then tighten the screw. i hope i was able to solve your problem. tnx
Feb 16, 2008 | Frigidaire GLTF1670A Front Load Washer
GE WSXH208A Front Load Washer Logo
104 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
