Just installed. I selected heavy duty cycle. The time on the washer when it started was like an hour...
(More)
Just installed. I selected heavy duty cycle. The time on the washer when it started was like an hour and 40 minutes. Is there a way to change the time of the cycle? Please advise?
maytag mah2400 door leaking. grey rubber inner door seal looks misshapen at bottom, with no visible...
(More)
maytag mah2400 door leaking. grey rubber inner door seal looks misshapen at bottom, with no visible tears or holes. there is an odd shaped hole on bottom of the door itself, below area fits inside of grey seal when the door is closed, and there was a "callous" of hard plastic like material along the front/bottom of door (above the hole, which appears to be part of the door, but not sure) . water leaks most during rinse cycle, and comes out in small stream in 3 or 4 places- the most water comes out when the water is filling tub and rinsing. I did a small load with just two bath mats and a lot of water was on the floor after that load. a larger load resulted in less water leaking out.
I need a diagram so I can take my maytag mah 24 front loader apart correctly. I have the dreaded nd...
(More)
I need a diagram so I can take my maytag mah 24 front loader apart correctly. I have the dreaded nd code, so I just know I have something stuck in the pump. ifruci@yahoo.com
I have a 24" front load washer mah2400a and the washer is leaking from the detergent dispenser....
(More)
I have a 24" front load washer mah2400a and the washer is leaking from the detergent dispenser. Out the back where the screen is on the top is an opening and water just pours out of there. I was wondering if you can help me fix this problem. If the opening is not suppose to be there, if something is missing or what is wrong. Thank you
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a...
written by jsrock516
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows...
This advice is for Kenmore Elite and Whirlpool Duet Front Loading washing machines displaying the "F22" error code. This is an indication of...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F02? error code. ?F02? is a Long Drain error. If the drain...
This advice is for Kenmore & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F21? error code. ?F21? is a Long Drain error. If the drain...
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
Washer and Dryer repair specialists.
Why hire som... Read More
Why hire someone else to fix your appliance when you can do it yourself? And we can help!
Download a step by step tutorial loaded with pics at www.shop.washermd.com
Our focus will always be to provide top-notch qua... Read More
Our focus will always be to provide top-notch quality service and customer satisfaction of repair services to our customers and partners on Warranty/non-Warranty Dimplex heaters, TV & Electronics, HVAC, Electricity, Home & Industrial Appliances, Sports & Exercise Equipment, Treadmills, Spas & Saunas, Office & Computer Peripherals.
