Televison & Video Logo
Posted on Sep 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm experiencing different colors on the tv when displaying an image.
Anonymous
Level 3:
Master:
  • Master 479 Answers
  • Posted on Sep 24, 2008
Anonymous
Master
Level 3:
Master:
Answers
479
Questions
0
Helped
154523
Points
1221
Its the problem of convergence on your tv.
so resolder convergence STK ic's. if that does not work, change (STK-ics).there are two on the board.change both of them.they are not too expensive.
they are located on the power supply board.easily available at local electric shop.
Anonymous
Level 3:
  • Master 4,234 Answers
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564649
Points
12312
If these colors appear to be like a 3-D image, the problem is in the convergence circuit. Please update this with the make and model and I will provide you with further information and instructions.
Thanks,
Dan
Distorted Image smart vizio tv 32 inch
It sounds that the T'Con board has failed. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Is there display drivers available for my NEX Plasma TV model PXT-42SX1B. I have a Computer that has a HDMI output which I can connect to my TV, but have not been able to correctly setup the display...
I'm sorry for the difficulties you're experiencing in viewing the Desktop correctly when connecting a computer to the TV. Unfortunately, there are no such drivers available for TV to make it compatible with a computer.
Please understand that the image from a connected computer will not display in full screen because of the difference between the display resolution of the television and the available resolutions on the computer. Setting the WIDE MODE (Zoom) option on the television to Full 1 or Full 2 will stretch the image to fill more of the television screen but will not fill the entire screen. This is normal operation.
I have searched online and found that 1024 X 768 will provide better experiencing than other resolution. It is required to set the resolution in the computer before connecting it to the TV. Please install if graphic card updates available from the computer manufacturer so that it will give option to select resolution in some cases.
Thanks for understanding. Please let me know if you require any clarifications.
6helpful
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
1helpful
Image quality
Connection Issues:
Low Light Boost:
To do this:
Hope this helps.
Good Luck.
Live, Love, Laugh.
6helpful
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
1helpful
Logitech web cam
Connection Issues:
Low Light Boost:
2answers
Picture quality relic WEBCAMS.
Connection Issues:
Low Light Boost:
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Shows Dark
Connection Issues:
Low Light Boost:
Intermittent Power Down and Backup
THE TV ONLY HEAR THE RELAY BUT NO PUSH IN ON NEVER
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
