Akai LCT3785TA 37 in. HDTV LCD Television
Problems with Akai LCT3785TA 37 in. HDTV LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Akai LCT3785TA 37 in. HDTV LCD...
Troubleshooting and Support
Solved Problems for Akai LCT3785TA 37 in. HDTV LCD Television RSS Feed
View More Results for Akai LCT3785TA 37 in. HDTV LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Akai LCT3785TA 37 in. HDTV LCD Television RSS Feed
Answer
I need to source a new power supply board for akai lct3785ta tv. Can u help?
Answer
won't switch on. Led remains red, flashes momentarily when on off button pressed. Also tried to... (More)
Answer
I can see only some channels. I can see from 30 to 39 channels and from 65 channel and up. The rest... (More)
Answer
I need to replace the buttons on the side of the TV. How do I remove the access panel without... (More)
Answer
Necesito un regulador de voltaje con el siguiente còdigo: BF52/FCPF/20N60 para...
Find a Manual
Akai LCT3785TA 37 in. HDTV LCD Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
Tips & How To Guides for the Akai LCT3785TA 37 in. HDTV LCD Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
don't through the comp out
don't through the television out the windows just yet written by sharna banna
vidios
my top tip of the day is ..... videos ,if your video player is playing up then try switching it off and on or get a new one it is entirely up to you. written by sharna banna
tips that may help you determinate what is the main problem of your TV
Hello to all well here are some tips that may help you determinate what is the main problem of your T.V'S 1- If you put you hand on the top of your... written by saidneurot
Dont Make This Mistake With Your Lcd Tv Set!
Ok lets just say you wake up one morning and the screen on your lcd tv set does not want to turn on, outside it is cold.The tv set turns on but the... written by livep9
Increase Your TV's Lifespan
Considering the whole goal of television salesmen is to have us return to buy more televisions when the old ones give out, perhaps we shouldn't trust... written by zabedav
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or... written by RixsFixes
Plasma TV no pictures
If you hear a relay clicking all the time when you turn your plasma TV on is often just a few capacitor and resistor to replace. Cheap and every body... written by wings_it
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Akai LCT3785TA 37 in. HDTV LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Akai LCT3785TA 37 in. HDTV LCD Television
Key Features
Screen Size
37 inch
Contrast Ratio
800:1
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV Television
Flat Panel Type
LCD Television
Display Resolution
1366 x 768 pixels
HDCP Support
With HDCP Support
LCD Response Time
8 ms
Connectors
Rear Input Connectors
S-Video x 1 · Component x 1 · Composite x 2 · 1 x D-Sub (RGB PC) · HDMI x 1
Display Capabilities
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Native Aspect Ratio
16:9
Image Quality
Brightness
550 cd/m
Viewing Angle
176
Akai Contact Information
Main support number4016584032
Email supportsupport@akaipro.com
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
