Our GE PTS25LHRBRWW refridgerator is running but it is slowing warming up to 50 degrees in both the freezer and the fridge. It seems to be blowing and running like usual.
ge has had alot of problems with the computer board that's in the back of the fridge.but first try this,open the freezer door,you should hear the fan blowing in there,if not you could have a bad evap fan motor,also touch the back wall of the freezer,if there's snow or ice on the back wall you have a defrost problem,you could have a bad heater or a defrost thermostat,also have you cleaned the coil on the bottom of the fridge?remove the bottom kick plate and vac it out,pull out the machine,remove the back bottom panel and vac that out,ashop vac works great for this vac out what you can and then blow out the coil and clean out any of the dust that you couldn't vac up.if the frame between the doors is hot that's one way of telling it's time to clean under there and when you have the back panel off make sure the fan is blowing back there.if everything looks good i would change the computer board,it costs around 150 to 200 hundred bucks.let me know what you find and if you need any more help let me know.
I have a GE BSY25GFMD and when you open the freezer door the compartment around the ice dispenser/opening is built up with frost . When you press against the inside of the freezer door you can feels ice/frost behind it. What do we do?
Also the bottom of the refrigerator (when closed) lets out alot of warm air.
Thank you
