I purchased the Logitech USB headset for the PS3 and PS2. I changed the accessories setting as the instruction manual indicated, but the graphic bar is set to the red region nearly at maximum even when i change the microphone volume. Also, when I speak, the graphic bar does not go up nor down. When I play PS3 games, i cannot hear anything through the headset or speak through the microphone. I'm wondering if the headset is broken or if the PS3 settings is wrong. The input and output for the PS3 is both set to "Logitech USB". Please help.
Re: I purchased the Logitech USB headset for the PS3 and...
It sounds like you bought a bad apple on that one. I've never had an issue selling any of these. Logitech is the best company out there for video game and PC accessories, that's why they are the only ones with a Playstation emblem on their box. Just bring it back to the store and they should replace it for you no problem.
go to Accessory Settings>Sudio Sevice Settings> Input Device:Logitech _ _ _ Headset > Output Device: Logitech _ _ _ Headset > OK, and you're done, dont forget to press OK if you don't it will not save, Have Fun :)
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share. Bluetooth:
The
PS3 uses Bluetooth version 2.0, and is compatible with all earlier
versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets
hit the market, so you will have to try it for yourself on PS3.
All brands of Bluetooth headset should work with the PS3.
USB: USB (wired) Headsets can also be used with the PS3.
Any of the PS2 compatible USB headsets should work with PS3 games.
USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
The
Bluetooth audio signal for PS3 only carries voice chat. The game sounds
and music are played through your TV or stereo receiver only.
If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
Make sure your Bluetooth headset is fully charged before you begin.
Check
your headset instructions for entering "pairing mode". Activate your
headsets' "pairing mode" so it can be recognized by the PS3.
On
the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then
down into "Accessory Settings", then down into "Manage Bluetooth
Devices".
With your headset in pairing
mode, follow the onscreen instructions and let the PS3 scan for your
headset. When your headset is found, follow the prompts and enter a
pass key (if necessary- the default is usually 0000 for all brands).
The pairing should now be complete.
If
you're using a USB (wired) headset, just plug it into one of the ports
on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting After
pairing a Bluetooth headset, or after plugging in a USB (wired)
headset, return to the XMB. Go to "Accessory Settings" and choose
"Audio Device Settings". You can test your headset here.
Your
headset should appear as the audio input/output device. If not, just
use the D-pad to highlight the Input line, then scroll until you see
yours. Any microphone you have used with your PS3 will be listed, but
only the current one will be available to select.
Set the "Microphone Level" to 3. You can change the level any time if needed.
Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings". If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
Set
the input to (your mic) and leave the output on (default)- one person
can chat with the other players, and the replys will play over your TV
speakers rather than into your mic. Great when sharing one console
because everyone can hear the team talk.
Set
the input and output to (default)- you will hear the game sound and
voice chat through your TV speakers but won't be able to talk back.
Great if you don't have a headset, or if you want the room to hear the
team chat.
Set the output to (default)
to use stereo headphones with your TV or receiver. Then set the input
to (your mic) and you can chat while wearing stereo headphones. Keeping
the mic close to your face could be a problem since both ears are
already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General: If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
Make
sure your headset battery is charged and working. Be aware that some
brands/models will need to be paired again after each recharge. It's
not a problem, it's just the way those models work.
Make
sure your controller is charged. Lots of strange things happen when the
controllers don't have enough power, like dropouts and headset
interference.
The headset should be set as the input/output device from the XMB.
For
Bluetooth users, make sure there are no other Bluetooth devices in use
near your PS3. Also try to eliminate any other radio frequency
interference if possible.
For USB users, make sure the connection is secure and there are no wire breaks.
Update your console to the current available firmware.
Pairing Problems:
If
the PS3 cannot locate your headset, make sure that your headset is in
pairing mode before you start scanning. The headset instructions will
tell you how to set yours to pairing mode.
If
your headset is missing from the device menu after you re-start your
PS3, you will have to pair again. Many headsets will only "remember"
one device at a time, so you may have to register again after using
your headset with a phone.
If your
headset appears on the Audio Device menu but is "grayed out" or not
selectable, it is not connected. Make sure the headset is charged, and
that it is on in standby. I should connect automatically when the Audio
Device menu is selected. Tap the call button on the headset if it does
not connect, or click on the Connect Bluetooth tab on screen.
Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
Most
in-game voice chat drops are simply network lag. Usually they go away
after a short time, so be patient. In extreme cases you may have to
leave a game and return to reset the chat function.
If
you use wireless internet, a low signal strength to
your modem/router can make voice chat malfunction. Make sure your
wireless signal is as strong as possible to your access point.
Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Playstation 3 Support Page- all the official manuals and tips in one place. You can also contact customer support via email from this page.
go to settings then go to accessory settings then go down to audio device settings when it says output device logitech usb headset click X on it then change it to system device
Hello my friend this should help you out. please remember to leave a positive rating for me and a testimonial if I helped you out!
The
The
Check
On
Devices".
If
Your
Set
Set
team chat.
and here's a video in case you are a visual learner.
Bluetooth Headset Setup
Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
JaWay (solution #1) is wrong. The usb cable is solely meant for charging the headset.
I had a few issues of my own. The manual is **** so don't follow that.
You mention somehting about a new PS3, taking that you have paired it
before with another. Turn on the headset and press the reset button with
the tip of a pen for a few seconds. The headset should now be reset and turned off.
Go to settings > accessory settings > manage bluetooth devices, from here you should be able to register a new headset. Initiate the search on your PS3. Hold the middle button for 10+ seconds. Till the led starts to flash alternating red and green. The PS3 should now be able to pick it up.
the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share. Bluetooth:
The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions.
All makes and brands of Bluetooth headset should work with the PS3.
The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
Mic Test and Volume Setting After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
Set the "Microphone Level" to 4. You can change the level any time if needed.
Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
