Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
