20 Most Recent
Toshiba 40RV525U 40 in. LCD TV Questions & Answers
Volumn increases automatically
You probably have a shorted button on the TV itself. It's not the remote. Consult a professional TV technician to resolve this issue.
My toshiba 40RV525u flat TV
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Where do I hook up the "audio out" from a vizio sound bar to a 40" toshiba tv?
If your TV has a headphone socket then you can use that.
If not, then because very few TVs are fitted with a basic stereo audio out then you need to use the TV's Digital Audio Out instead. This is probably on an Optical connector.
Some soundbars have a direct input for Optical. Other's don't. So the signal needs to be converted from light pulses in to a basic stereo electrical signal. This can't be done with a piece of wire or with adapter plugs. It needs some electronics to translate the signal from light to electricity.
The adapters range in price up to 60 Pounds sterling. But here's one for peanuts from Amazon
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
