Question about Motorola Mag One BPR40 Two Way Radio
Re: MagOne by Motorola, BPR40 -- What button should I push and how many times to make a radio stop beeping repeatedly before I can communicate? Thanks!
Posted by dsaj1123 on
eradiostore
  • Motorola Master
  • 1,658 Answers
None of the buttons will solve this issue.
A repeating low tone is heard when you press the PTT if your battery level is low. You may have a bad or poorly charged battery. It takes more energy to transmit than to receive, so the first place this shows up is when pressing the PTT. A quick way to check this is to swap batteries with a known good radio and see if the problem switches to the other radio.
Battery tips: Clean your battery contacts with a pencil eraser to remove the film caused by hand oil. Always charge your battery with the radio turned off. And be certain your charger is plugged into an outlet that is not connected to a light switch shutting off power. Batteries last approx. 2 years. Check your battery's date code to see its age. (3 or 4 digit number, first one-two numbers are the year, second two are the week of the year. example: 1132 would be 2011 the 32nd week)
If the above does not solve your problem, you should see your local Motorola dealer, or a nationwide repair center for more assistance. Current flat rate repair on this style unit is typically around $69.
FYI: Your buttons are likely top button = monitor/sticky monitor and the bottom button could be hi/low power, scan or one of several other features. Each button has a short and a long press option.
Best regards.
Posted on Aug 09, 2011
Magone bpr40 - How do you remove the Board from Metal back plate. All Screws are now off of board, But still not coming apart.
Great question! Clear and easy to understand! The volume and channel switches likely have a metal "O" ring that screws down on the threaded switch and holds the top of the radio to the housing. Remove the knobs, then use a really small flathead screwdriver, insert it into a notch in the "O" ring and unscrew. Be careful and you should be fine. If not, get it to a radio repair shop.
Apr 16, 2015 | Motorola Mag One BPR40 Two Way Radio
We have 6 Mag one BPR40 radio's all of a sudden you can't hear anything in the ear pieces.
Very strange! Assuming no programming has changed: check that all earpieces are tight into the radio. Unplug, check for audio without an earpiece and replug into radio. Make certain your batteries are FRESH (less than 1 year old) and fully charged. I am assuming you are using earpieces approved for the Motorola radio. Many speakers do not work and several earpieces are not designed well. Stay away from the auction site cheap ones. You get what you pay for, including failures. For several audio jacks to fail at once would be very unusual. Try a new earpiece. I suspect earpiece failure more than anything. All tests after this require checking programming and/or taking the radio apart.
Apr 15, 2015 | Motorola 4 Magone Bpr40 Uhf
How to I syncronize all my radios so they work together
Karen-
Contact Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
How do i sync Two-way radio AAH84RCS8AA1AN
These are dealer programmable using Motorola proprietary software and the appropriate cable. Most Motorola dealers could program one or more of the radios for you.
Mar 16, 2014 | Motorola MagOne BPR40 UHF 8-channel...
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Jun 15, 2011 | Motorola Mag One BPR40 Two Way Radio
Are my Motorola MagOne BPR40 handheld radios narrowband capable?
Yes. They are programmable to either wideband or narrowband on a per channel basis.
Best regards.
Feb 16, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Mag One BPR40 Two Way Radio Logo
1,032 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
