Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
Is motorola cls-1110 compatible with bpr40 radios
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
If John's info doesn't help you can consider contacting Get Support .
Mark
Motorola Support
Posted on Mar 15, 2015
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
Yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
My motorola cls 1110 turns on, but no communication can be heard
internal regulation has failed
the RX and TX circuits share a common control circuit the PLL and its micro so perhaps this parts 5volt supply has failed
some radios has a small two pin fuse that looks like a 3 pin black small to92 transistor
perhaps the batterys cells are bad check the packs output is ok
Nov 28, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Those the motorola cls 1110 compatible with the cobra frs-100?
Hi Miguel,
I think you are asking if the Motorola is compatable with the Cobra, is that correct, if so simple answer NO!, they are completely different makes, made by different manufacturers, in different countries.
You cannot clone from one to the other, without damaging one or both radios.
If this has answered your query, I'm happy to have done so.
Regards,
Peter
Jan 16, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
What channel is 467.5625 on mymotorola cls 1110
Here is a link to the user guide for the CLS1110: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf The freq chart is on page 39.
Sorry to let you know 467.5625 is not one of the frequencies.
Best regards.
What are the frequencies for a motorola cls 1410 radio
Here's a link to the user guide for the CLS model radios. You will find the frequency list on pages 39-41.
Best regards.
Aug 04, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My motorola cls 1110 is frozen and the screen says f 8
Here is a link to the user guide. Your radio is a one channel radio, and the F8 indicates it is set to frequency number eight.
Dec 07, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
133 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
