Question about Motorola Mag One BPR40 Two Way Radio
Mag One Radio - Static
I have about 20 Motorola Mag One radios that I use for my business. Lately, we have been getting a lot of static that just comes on even when nobody is transmitting. There is also about a second of ongoing static at the end of each transmission. Any ideas what could be causing this?
Posted by John Oldefendt on
eradiostore
  • Motorola Master
  • 1,658 Answers
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Best regards.
Posted on Jul 13, 2012
sadika_t
    New Friend:
Hi i recently bought 2 mag one radios and when i took it to be program with the frequency it keep giving me a programming error. can someone please tell me the cause
Posted on Aug 29, 2012
  • 1 more comment
  • eradiostore
    eradiostore Aug 29, 2012
    Double check your programming set-up and cable. It is possible you have a programming cable which has gone bad.
  • eradiostore
    Another issue might happen if you are attempting to program a BPR40 with software older than the previous programming. And one final thought, if your radio's light seems to stay locked on after programming, your radio is in need of repair.
  • John L radiodude365 Sep 24, 2012
    It is really easy to buy the wrong programming cable. I only use Motorola cables, they cost a lot more but they always work. Other than that, it was never intended to be programmed by consumers, you need the correct setup and as eRadio said, the most current copy of the software. If you have never programmed one, it is intimidating.While I have an online store, we do not offer "free Help" on eBay or garage sales radios. Best to send it in for programming. They got rid of them for a reason.
5 Related Answers
Anonymous
SOURCE: Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Posted on Apr 16, 2007
Anonymous
  • 250 Answers
SOURCE: FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 01, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: motorola spirit mu21cv
Sounds like you do not have your radios programmed to match one another. The MU21CV is a user programmable model. You might call your local Motorola dealer or one of the companies online to have someone walk you through programming the radio(s). With this model it can appear the radio is not powering up, when it simply is not programmed correctly.
Posted on Jun 24, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola T5000 Two Pack 2-Way Radio
Generally a crackling sound coming through a speaker indicated the speaker is damaged (or blown). This can happen due to phyical damage such as dropping; old age' or running the device at full volume most of the time. The T5000 is a non-repairable radio. If less than one year old you may be able to get it replaced under warrranty. If more than one year old, you will need to replace the unit.
Posted on Oct 01, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Radio will not transmit, display seems wrong
Here is a link to the user manual for the SV600R. http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf Follow the instructions to reprogram the affected radio. Note: The problem you are describing may not be simply programming. The radio problem may be non-reversible. You might also try a new battery, or switch the battery from the other unit for a test, just to see if the battery is bad.
Posted on Jun 08, 2009
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
The only way I can receive is to have static all the time, how can I receive and transmit without static
has to do with the electrons in the air waves . Have you noticed that when you are near businesses with flourecent lights you pick up a lot of static? A traffic light may change and the electrical impulses from the change can be heard in your radio.It could also be the vehicle you are driving .Are you using a cigarette lighter plug which will give you static also . Do you have a noise blanker switch on the radio ? if yes make sure it is on and an A N L switch ,make sure it is on .
May 15, 2015 | Radio Communications
All my radio will transmit is static
First check your battery pack. A bad or low battery will produce static. Secondly, check your antenna. If it seems to turnaround inside when you hold on to the threads and the outer sheath, you need a new antenna. Beyond this your radio is likely in need of repair.
Best regards.
Apr 04, 2014 | Motorola Mag One BPR40 Two Way Radio
CP185 has intermittent static, when pressing button to talk screen displays "channel busy" and battery will not keep a charge.
Could be one of several issues. A few which come to mind are:
1) You have a bad or poorly charged battery. Static is a sign of a bad or poorly charged battery. Try swapping a battery from another radio, with a known good battery and see if the problem is solve. If this resolves the issue check your battery and charger. Tip: Clean all charge contacts with a pencil eraser to ensure good charging. Also, check your 3- or 4-digit date code on the battery. If more than 2 years old, replace the battery. (4-digit date code example 1303 would be 2013 the 3rd week; on 3-digit date codes the first number is the year and the next two the week of the year.)
2) You are trying to use the radio in an area where you are experiences high RF on your frequency. This is the "busy"... someone/something is on or near your radio's frequency and interfering with transmission. Try your radio at a different location and see if the problem persists.
3) Another radio in the workgroup is stuck in transmit, causing static, and the channel busy. Turn off other radios, one at a time, and see if the problem still exists.
4) Or if you have an audio device plugged into the radio, try unplugging it and see if the problem stops. FYI: All audio devices must be plugged or unplugged with the radio shut off. If you plug one in with the radio turned on, you can experience some unexpected intermittent issues.
If none of these seem to be the problem, your radio is likely in need of repair.
Best regards.
Jan 17, 2013 | Motorola CP185 (16 Channels) Two Way Radio
Can not get static out of radio i have a cobra 29 with weather channel the squ knob seem 2 b not working sometimes can u help me
Turn the squelch down, and the RF gain all the way up.
You need to realize that some times, there is not a lot of noise out there. Right now lately there has been due to skip. But it does die down. When you hear a lot of noise for a while, then it goes away, it messes with your head. You don't hear anything, but that's because its quite out. I would test it by talking to some one on the radio. If you can hear them just fine even though you don't hear a lot of static, then its just quiet out.
Jul 23, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
The 'mute' button is on the radio and I can't get it off. The model of the radio is Motorola XTR446. Thanks
Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
The XTR446 does not have "mute". But what you might be experiencing is a problem with the radios matching one another completely, such as the "interference code" being set differently among the radios. Check your frequency and code to see that they match the other radios exactly. Also, check your radio's mic hole for dust, dirt or debris. This can mute/muffle transmissions.
If this does not solve the problem, you may have a radio in need of repair.
Best regards.
Sep 28, 2010 | Motorola Radio Communications
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
May 15, 2010 | Motorola Walkie Talkie 2-Way Radio
The radio in my 2003 dodge neon has a lot of static on every radio station i have checked the antenna connection and it is good. also the cd player has started to skip more lately dont know if it is...
If the static doesn't change tempo with engine RPM, the unit is probably going bad. If it does your radio suppression is faulty. Could be ignition wires or the antenna going bad.
Mar 30, 2010 | 2003 Dodge Neon
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola Mag One BPR40 Two Way Radio Logo
899 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
