20 Most Recent
Royal 120 Pd 120pd Plus Desktop Printing Calculator Questions & Answers
Where can I get a Manual for a Royal Scriptor ll Typewriter?
You can try searching for a manual for the Royal Scriptor II typewriter on the manufacturer's website or on websites that specialize in providing manuals and instructions for various products. Additionally, you may be able to find a digital copy of the manual on online marketplaces or auction websites, such as eBay or Amazon. If you are unable to find a manual online, you can try contacting Royal's customer support for assistance in obtaining one.
Royal AX160 advances paper at an angle why?
you might need to calibrate a part of the typewriter in order to fix this or there might be broken part of the typewriter.
Please verify how the paper should be advanced based on the typewriter manual. And if it's different in the manual, then you might need to call Royal directly to ask for the closest repair shop you can send the typewriter to so that the issue can be fixed.
Thank you.
What's a PCB on a Royal 1212X shredder? And how do I know the PCB is the problem?
A pcb is a printed circuit board. You can visually check it for very small burn spots or tiny melted disconnections, or swollen or burst capacitors; but any repairs of the PCB are risky because of the interdependencies of any circuitry.
If you've already checked the mechanical workings, you might try to find a replacement PCB if you're convinced that's the problem. They're often not even sold, so a whole new unit would be required.
Welcome to the wonderful world of planned obsolescence.
My Royal Alpha 9170 is feeding to quickly, resulting in a paper and ribbon jam and resulting in a printer error.
hi
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved
Royal 1610X wheels
Casters enable it mobility from office to office. Royal 1610X is a cross cut paper shredder designed for heavy duty commercial and office usage. This Royal office paper shredder will shred up to 12 sheets of paper at once. Royal 1610x also provides continuous shredding of 10 sheets of 16 inch wide computer form paper.
