20 Most Recent Royal VF1012mx Shredder Questions & Answers
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Royal VF1012mx... | Answered on Aug 27, 2016
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Royal VF1012mx... | Answered on Mar 13, 2014
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Royal VF1012mx... | Answered on Feb 13, 2012
Unplug the machine.
Remove the waste bin.
Remove 4 screws inside underneath to take cutting head off the basket/cabinet.
Turn the cutting head over and remove 6 screws that hold the top cover onto the bottom. Turn the unit back over and remove the top cover...remove the medallion if jammed...check the gear train to see if it has broken any teeth in the drive gears.
If you need parts contact Royal at 1-800-524-0799.
Royal VF1012mx... | Answered on Jul 20, 2011
Have you ever "oiled" the cutting blades...all cross-cut shredders should be oiled regularly otherwise they clog up with the paper and debris generated by the cutting of the paper...the oil helps feed this material on thro into the shredding bin.
Royal VF1012mx... | Answered on Mar 30, 2011
Have you ever oiled the cutting shafts....all cross-cut shredders require some amount of lubrication....the more you use it the more it should be lubricated. You can get a bottle of lightweight shredder oil from the same place you got the machine.
Royal VF1012mx... | Answered on Feb 13, 2011
Have you ever oiled the machine...its a cross cut shredder and you are supposed to regularly lubricate the cuttting shafts with shredder oil.
Royal VF1012mx... | Answered on Feb 09, 2011
For parts assistance give Royal a call at 1-800-524-0799.
Royal VF1012mx... | Answered on Jan 29, 2011
Try cleaning the eyes first...if that dosnt work and you feel they have to be replaced you can contact Royal at 1-800-524-0799 for parts assistance.
Royal VF1012mx... | Answered on Jan 17, 2011
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
Royal VF1012mx... | Answered on Jan 16, 2011
Royal VF1012mx Shredder Logo
Popular Tags
69 questions posted
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Royal Office Equipment & Supplies
Most Popular Question
piece junk mail
  • Office Equipment & Supplies
