It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
Hold 0 and 8 in the same time and turn on AD will appear you can put the 690 with numbers and press the start key with show hdd format enter the number 2 if is not on screen and pres start you must wait some sec and the message reboot the machine will be show.Turn of and after 20 sec on again.If the error is again change the HDD.
1) the vhs display can be defectivie a) for lack of voltage is missing b) display is defective. 2) you can buy a new ones converter. go to some appliances stores and search by new ones. 3) However you can go to the repair shop TV for fix it, and ask about the cost vs to buy a new ones converter. God bless you
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer. 2.Click to select any options that are required to start the computer from the CD drive if you are prompted. 3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console. 4.Press 1 (One) to select windows XP and then hit enter. 5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER. 6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER. 7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
to list a contact the easy way just type the number it and press options and it will display save go from there
if some one called and u missed it when the screen shows one missed call it should show the number if not it was private u can also go in to call log and go to dialled calls.recived calls.and missed calls and will show u the numbers
