The easiest way to connect your new conroller to your xbox is to plug it into the usb port in the front. This will identify that controller from then on to that Xbox 360 when you use it wireless. (or until you connect it to a different Xbox 360).
You might not be pushing the correct button when trying to sync your controller with the Xbox 30. On the controller you have the main guide button but the button you want is the one on top of the controller to the left of the port were you plug in your charge and play cord. It is small an of the same color as the controller. You need to push it along with the connect button on the Xbox for them to sync.
If you are still having issues then you might have weak batteries. Make sure your batteries are charged and ready to go. Try using AA batteries if you can and see if that solves your issue?
Also, some devices in your house can cause interference with your controllers if they are operating on the same frequency. (i.e. wireless phones, mocrowaves...etc.) Make sure your xbox is away from locations with conflicting frequencies. Metal shelves can also cause havoc on wireless controllers. Make sure your xbox is free of clutter and has breathing room.
Hope this helps.
