SOURCE: samsung syncmaster 206bw turning on and of, light
First, it is good to see others have had this issue. I have had my monitor going on two years or so. In the last two months, turning it on it takes longer and longer for it to 'warm up' before it stays on. I also have the blinking on and off with the desktop and functions working fine underneath. Today it took about two hours. It went on fast when I used a hair dryer to warm it up through the air flow holes on back/top of the monitor. Within 30 seconds, it flipped on. So, I'm hearing that a it's a power supply issue/inverter. Interesting. I am going to do a bit more research before I take it apart. It would be good to know if others have a problem? and, other solutions?
Craig
Wichita, KS
SOURCE: samsung syncmaster 740n monitor problem
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
SOURCE: Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
