Samsung SL310W Digital Camera Logo
A
Anonymous Posted on Jul 28, 2011
Hello, I am getting a message saying: USB Device not recognized I download photos all of the time and now any usb port on my computer gives me the same message. Any idea how to fix this? Thanks! Ed Gardner
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Jul 28, 2011
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444235
Points
622693
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Having major usb issue
Do a restore, to back before you installed it, you just want to do the restore point before the install then you start fresh and then make sure under your device settings that you have more than one usb port active, designate under the default programs that the auto play is on, you get it, easy.
I have lg ms690 mobile device. When I attach the usb to my laptop, I get the message - one of your USB devices is malfunctioned and windows does not recognize it. I downloaded an updated version and still...
Ok I experienced this problem before..try to plugged your phone to the other usb port of your laptop try it at the back the power of the usb port there is sufficient to make your device to function properly..I tell you this because some of the usb port except from the back of a pc CPU gives insufficient power to a usb device that can make the usb that was plugged in it not work properly and not recognized by windows.
1helpful
When i connect usb for photo frame into my computer is says device not recognized. then say reconect and if windows does not recognize replaces the device but i purchused two for chrismas presents and they...
Try connecting each device to a different computer, to see if the devices work at all.
Try every USB port on your computer, to see if you have one "bad" USB port.
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
EasyShare DX6440 "USB Device not recognized"
What operating system are you using?
If you have xp or vista, you can uninstall the software and transfer the pictures since these operating system has built in drivers.
USB device not recognized
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue: http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
1helpful
2answers
Can not connect to USB Port - Error Message (Warning - Drive G:\ containing photos in library has been disconnected. Please reconnect drive and click retry.) Never have gotten this message after hun
Try unplugging a few other things like USB hubs before plugging in the camera. If this does not work, please advise what other messages you get when attempting to connect the camera.
If you are PC savvy, check out device manager in control panel to see if this gives you any more indication as to what the problem is.
2helpful
3answers
Barbie girl mp3 player isn't recognized in Windows
remove the backplate, get a pin and push the reset button at the back of the barbiegirl
Usb
your usb device is use less now.
replace it if u have warrenty of it.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
