20 Most Recent Kodak EasyShare DX6440 Digital Camera Questions & Answers
SD cards go up to 2GB in size. SDHC cards are from 4GB to 32GB in size. SDHC is an extension to SD, and SDHC cards will not work in devices not designed to accept them, whereas SD cards will work in device that accepts SDHC cards.
Kodak EasyShare... • Answered on Jul 13, 2014
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Kodak EasyShare... • Answered on Nov 03, 2012
You may view/download the user guide here.
Kodak EasyShare... • Answered on Oct 06, 2012
The DX6440 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Kodak EasyShare... • Answered on Apr 19, 2012
Hey i had the same problem. Saw your post and none others. Finnaly i gave up looking and just started tearing my camera apart. My camera is a Kodac 7630 so the diss assembly may be a little different but with the removal of a half dozen screws i got to the inside of the dial. It didnt feel sticky but i took it apart any way and cleaned all the touching serfaces of the dial with rubbing alchohol and my problem is solved. took about 30 min and there was really no danger of harming the camera. Its amazing the just a little stickyness caused the problem i was having because i could push with all my might and the dian didnt budge. i thought a part was broken in there. i think this is because you allso have to push down to move the dial so a little tickyness combined with your downward presure makes it impossible to turn.
good luck
Kodak EasyShare... • Answered on Oct 02, 2011
Correct. You cannot use SDHC cards in the CX6200 and the CX6330. SD cards max out at 2GB.
Kodak EasyShare... • Answered on Jul 27, 2011
There is a very easy way to download those pictures to your PC.
Checkout this tip that I wrote about that.
How to easily download Pictures from Digital Camera
heatman101
Kodak EasyShare... • Answered on Apr 21, 2011
Can you give a better explanation of what you mean by off track? Do you mean it doesn't track with the zoom or is it not correctly aligned compared to the screen?
Viewfinders are never very accurate on that class of camera, you would have to dismantle to see if anything has come adrift within the viewfinder, and unless you can do it yourself it wont be economical.
Just shoot loose if using the viewfinder and use the screen if it's critical.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Kodak EasyShare... • Answered on Mar 02, 2011
if its shut hard you might need to take it to a store but if you play with it a litte it might become lose
Kodak EasyShare... • Answered on Dec 29, 2010
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Kodak EasyShare... • Answered on Nov 09, 2010
You can view it online and download it from
http://www.kodak.com/global/en/service/products/ekn027036.jhtml?pq-path=1115
Kodak EasyShare... • Answered on Sep 29, 2010
Yes. In fact, you can download it here. If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Kodak EasyShare... • Answered on Sep 26, 2010
You can view the manual online and/or download the PDF version from the manufacturer's web site at
Kodak EasyShare... • Answered on Sep 23, 2010
Please elaborate the problem providing us with more details like the name of the email service you use (Yahoo, GMail) and also the operating system of your computer (Windows XP/Vista)
Kindly reply to this post with the detials. Thanks for using FixYa.
Kodak EasyShare... • Answered on Jul 01, 2010
Make sure that you are using a fully charged battery and of course the recommended battery for your camera such as 2 AA lithium battery or Ni-mh battery. If you already done with all this thing it time to contact Kodak at 1 800 235 6325 ext 12 and send your camera for repair
Kodak EasyShare... • Answered on Feb 04, 2010
This charger will normally only charge if you're using KODAK rechargeble batteries.
Your batteries might be in need of exchange.
Kodak EasyShare... • Answered on Jan 25, 2010
Kodak EasyShare DX6440 Digital Camera Logo
49 questions posted
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
will not hold charge
  • Cameras
