Question about Samsung SL202 Digital Camera
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
Posted by capricorn15 on
Edward Putt Jr.
    New Friend:
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Posted on Dec 30, 2010
  • Edward Putt Jr. Dec 30, 2010
    Ohh yeah, this is where i got this idea fromhttp://www.fixya.com/support/t4041001-sa...
  • JANE
    JANE May 12, 2014
    it makes a weird sound when i ON the camera.and the screen is not very clear
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
Camera not turning on
my camera just wont turn on period and just used it like half an hour ago
May 31, 2008 | Samsung Digimax D53 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
[email protected]
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Open Questions:
See all Samsung SL202 Digital Camera Questions
Samsung SL202 Digital Camera Logo
2,093 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
