You can definately get sound without them but you must have an internal speaker inside the computer. an alternative option would be to plug headphones into the line out port in the back of the computer.
Now you will need to check inside the computer for the internal speaker. It will be a little black round plastic bit with two wires it should be plugged in to the motherboard at the bottom right hand corner. This is the Front Panel Instrumentation and Illumination Area or just F_PANEL for short on most motherboards. If there is one plugged in, then you need to go to the audio properties and select internal audio.
Hope this helps.
