Posted on Jul 11, 2011
Scan driver - Office Equipment & Supplies
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
173
Points
What problems do you have with your scan driver????
If you need to scan a document, and you have problems with your scanner, you can use the Popfax service:
1. Subscribe for Popfax fax email paid or free offer
2. Send the document you wanted to scan by fax, from your fax machine to the Popfax fax number
3. ou will receive the document in PDF on your email .
Easy and cheap! Try it now!
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
tip
How to Scan in Windows 7 without Using HP Software
Introduction
Windows7 provides a basic set of scanning drivers, also referred to asWindows Image Aquisition (WIA) drivers, that you can use as analternative to scan a document when you cannot scan using the HPdrivers. You might choose to use these scanning drivers for one of thefollowing reasons:
  • Your product released before Windows7 and HP has not released drivers that support scanning for your product.
  • You have not installed the available HP software that includes scanning.
  • You are troubleshooting a scanning problem and trying to identify the source of the problem.
Method one: Scanning with Windows Live Photo Gallery
To scan a document using Windows Live Photo Gallery in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, and then click Windows Live Photo Gallery.
  2. Click File, and then click Import From Camera or Scanner.
  3. Click the product you are using to scan, and then click Import.
  4. Make any desired setting changes, and then click Scan.
Method two: Scanning with Paint
To scan a document using Paint in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, click Accessories, and then click Paint.
  2. Click the Paint button (c01886001.gif), and then click From Camera or Scanner.
  3. Make any desired setting changes, and then click Scan.
Method three: Scanning with Windows Fax and Scan
To scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, and then click Windows Fax and Scan.
  2. Click New Scan.
Does not work with windows 7; cannot connect to scanner
You have to replace the original Konica Minolta driver with the custom one I have created below. Here are the detailed steps.
1) Install the Konica Minolta XP software in Vista/Win7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c:\newminolta\sonyscanners.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta XXXX (depending on model) and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c:\newminolta\sonyscanners.inf and click OK
14. Click Next. Windows should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
17. If you are trying to use a Minolta 5400 with firewire in Windows 7, you have to change your 1394 driver to the legacy windows 1394 driver in order for the scanner to detect. Google for instructions as it's too detailed to add in here.
18. The above driver should relink virtually all known Minolta scanners (USB/SCSI/Firewire) to the Windows TWAIN driver so it will work with the legacy Minolta software.
Will this scanner work on Vista or must I use in on a computer that has XP? How do I get it to work with Vista? Would it be easier if I got Windows 7?
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSIScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSIScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSIScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSIScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSIScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c: ewminoltasonyscanners.inf)
13. Browse to c: ewminoltasonyscanners.inf and click OK
1helpful
Looking for driver for Minolta Scan Elite 5400 (not II) in wndows7
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
2answers
Is there a fix for being able to scan hpj3680
Hi Melinda,
Windows7 provides a basic set of scanning drivers, also referred to as Windows Image Aquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers. You might choose to use these scanning drivers for one of the following reasons:
ScanningUse one of the following three methods to scan a document. Method one: Scanning with Windows Live Photo GalleryTo scan a document using Windows Live Photo Gallery in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , and then click Windows Live Photo Gallery .
  2. Click File , and then click Import From Camera or Scanner .
  3. Click the product you are using to scan, and then click Import .
  4. Make any desired setting changes, and then click Scan .
Method two: Scanning with PaintTo scan a document using Paint in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , click Accessories , and then click Paint .
  2. Click the Paint button (c01886001.gif ), and then click From Camera or Scanner .
  3. Make any desired setting changes, and then click Scan .
Method three: Scanning with Windows Fax and ScanTo scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
Please reply if the problem persists.
Regards,
Rizwan
I dont know how to scan from my printer hp psc 1315. printing and copy fine. please help me
Hello, Windows XP provides a basic set of scanning drivers, also referred to as Windows Image Aquisition (WIA) drivers, which you can use as an alternative to scan a document when you cannot scan using the HP drivers. You might choose to use these scanning drivers for one of the following reasons:
  • Your product released before Windows XP and HP has not released drivers that support scanning for your product.
Scanning with Paint To scan a document using Paint in Windows XP , follow these steps: NOTE: Before you begin, make sure that the product is connected to your computer.
Click Start , point to All Programs , point to Accessories , and then click Paint .Click File , and then click From Scanner or Camera .Make any desired setting changes.Click Scan .
2answers
Drvers for scan Plus IV-850c
go to scan Plus web site and enter the product detail and download drivers.
What is the difference between direct scanning and scanning through software (after installing driver)
Scanning through software enables you to crop and adjust settings before scanning.
k24674
ADMIN Andrew
ADMIN Andrew
