"F2" on a Whirlpool means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable, too.
On some models, you have to peel off the old keypad and stick on a new one. If
you (or someone you know) might want to replace it yourself, I have
uploaded a handy guide with pictures showing you what's typically
involved. It's here.
On some models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple DIY job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number (with suffix) from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you have to replace the frame, you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
