You can use a HP recovery disc for your model computer which will return the computer to out of the box condition. You may need to purchase this disc from the HP WEB site. If you just want to wipe the hard disk clean and sell it without an operating system installed then you can use this program. Wipe Data off Hard Disk with Darik's Boot and Nuke, (DBAN) Create a Darik's Boot and Nuke on CD disc, then boot up the computer with this disc. http://www.dban.org/download
If you wipe your drive you will need to load another operating system on it unless you want to sell it ?
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart or if you are using a USB insert your usb drive click start right click on my computer select open you should see your USB drive right click then select format another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps www.WipeDrive.com
Both scratches and dust can affect the playability of a game disc. Cleaning it can usually do the trick. Several techniques will clean the disc and make it useful again, saving time and money that would have been spent on a new game.
1. Before you apply disc cleaner, wipe with a microfiber cloth or other soft fabric. Wipe from the center of the disc outward. Don't wipe your Wii game disc in a circular motion, as this can damage it further. Test it to see if it works.
2. Rinse the disc with water if the first step didn't work. This will get rid of any oils that have gotten on the disc. If you see gunk that won't easily rinse off, use your fingers and a light dish soap to wipe it off underneath the stream of water. Remember to wipe from inside out, the light soap will serve as disc cleaner.
3. Dry the disc. First, shake off any excess water. Then set it out to air dry. Don't use a cloth for this step as that could add little fibers that may cause trouble. Once the disc is completely dry, try it in your Nintendo Wii to see if the disc repair worked.
4. Use rubbing alcohol with a cotton swab and gently coat the disc. Allow to dry. The disc will dry much quicker when wet with alcohol than it did with water. Still, you should wait until it's completely dry before you try the game disc in your Wii. By now, your disc should be working. Most disc read errors on Wiis are due to dust and dirt, rather than an actual scratch.
5. Spread toothpaste on the disc. This disc repair method should be used as a last resort. Using plain, white toothpaste, rub a quarter-sized amount in a circular motion with your fingers on the disc. Cover the reflective side of the disc completely. There should be a thin layer over the game disc when you're done.
6. Let the toothpaste sit on the disc until it is dry. This shouldn't take more than 10 minutes, although it depends on how much toothpaste you used.
7. Run the disc under warm water, rubbing the toothpaste off with your thumb. Make sure you get it all off and the disc is thoroughly rinsed. Allow to air dry. Then try the game.
You could also reload your machine clean once very 6 to 12 months ... keeping logs of those programs you *want* to keep ..
thus when you wipe and reload, you will only load those applications you want to have.. and not have tried fifty different apps leaving garbage behind on your machine ...
You could also build a backup of your system inbetween these rebuilds .... so that you can re-load to a known configuration and build upon it.
These "optimizers" are only a temporary measure.. their only *real* power is when they are installed from a CLEAN running state, so that *they* can track changes made to the system and wipe out the garbage..
and lastly ... don't play with garbage, and you won't need a cleaner / optimizer.
Why didn't you just get rid of the virus which is the easy solution? Or you could have done a System Restore to a restore point (date and time) before you caught the virus.
Unfortunately most times those Recovery Discs don't work. The best Recovery Disk that works is the one the manufacturer puts on your hard drive.
Have you checked your hard drive to see if there is a Recovery Partition on it?
See if you can run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Try fogging it with your breath and wipe the disc from the INSIDE circle and straight OUT to the outside rim of it. Don't rub all around the disc; it'll just ruin it. Start from the inside, wipe straight out.
Alternatively, you could use a glasses cleaning polishing cloth. Again, wipe from the inside out. Then add some glass cleaner onto it and (once again) wipe it gently. If you have any Carnauba car wax, use a small amount on there; it'll fill in the scratches that are there. For the last time, wipe from the inside out.
It's a lot, I know, but I hope it works for you.
There could be several things wrong. Let's start with the most basic - is the disc inserted correctly? The holographic side needs to be on the left when inserting it. Then, make sure there are no scratches or smudges on the bottom of the disc. A common solution is to wipe it with a cloth or even your shirt if you don't have one handy. Look on the holographic side of the disc to make sure there isn't anything left on it. After cleaning thoroughly, try playing the disc again.
If you're still having a problem, try restarting the Wii console. However, there's always a possibility that you have a bad disc or, if you're unable to play any games, a bad console.
