Asus system recovery soft ware ? I wish to add this . 1. a New Hard disc (HDD) IS installed as old one is lost . 2. when powered on a blue screen comes asking for password. ? Is this beca
1 A new HDD us installed as old one is lost . 2. A blue screen comes when powered on asking for PASSWORD . ( SEEMS TO ORIGINATE from lack of system on HDD or what's it? 3. now what steps I should take . first remove ( tackle ) Bios password or once system is installed on HDD this password problem disappears automatically . . Should I use Asus system recovery disc ignoring Bios password ( presuming this disappears once system is installed ) I request help stepwise to proceed for trouble shooting as I find all this troubles originating from Asus .com by not supplying System discs instead formatting on hard discs. Please advise as to what to do stepwise ( problem ; No system on Hard disc . 2.Ablue screen comes when powered on asking for Password ( no Bios as there's no system or it has nothing to do with it & a separate problem to be looked into .) Please advise as to how to proceed stepwise. Thanks, regards. N.S.Rao.
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive). You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it. To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended) CAUTION: Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created. Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer. To reinstall drivers and applications:
Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
Click "Next".
Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
Click "Install".
Follow the on-screen prompts to complete the installation process.
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
A new Os (XP) will allow the second drive even if the old one will not. Of course you can always add a USB hard drive and a USB PCI card to make it all work. What are you using this pc for seems a little old for todays applications. Suggestion If your going to use this that you Replace the main hard drive with a 120GB or larger, new video card at least 256MB if not 512 and at least 1 gig of memory as I believe it will only take a max of 1 gig. you cannot use vista as it requires more resources than this Pc can give to support the OS. you may want to try XP LITE as well one you get XP installed to speed it up a bit!
yah its possible to recover the data from hdd. just baught a recovery tool cd and recover your data hdd may has a bad sectores .u run a bad sector recover soft ware .
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Hello suresh_7chan, This can be either a software problem or a hardware proble.
Most likely hardware problem is the primary hdd. (Hard disk drive). To check the hardware end of things. Re-check all data & power connections within the system, paying close attention to your primary hard disk drive. Most blue screens leave a message. If you can write down the message from a blue screen it can be helpful. (Some blue screens go by very fast & it may be too hard to write down the message generated by windows). Another suggestion. If your hdd is large enough, 80GB or more. You can load your windows CD into your CD-Rom drive & boot to the windows CD. In the few screens that windows will display during setup. You'll have the option to create a second partition within the free space of your hdd. Create a new partition & allow windows to do a quick format.
Once completed, install windows into that new partition. Up date windows to SP2, at least. If windows runs correctly without blue screens or sudden restarts, than your old windows is either infected with a virus/worm or just messed up. install antivirus software & run a full system scan. You can use windows disk manager software to change the old C:\ to something like G:\. To run windows disk manager software, click the start button & open run. Type, diskmgmt.msc into the run window & click ok.
Again, if your new install of windows functions correctly & no virus has been found you can copy your old data to your new install of windows. (This is so you do not loose your data).
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
